Page 9 of 12
Re: Iz Amerike
Posted: 19 Feb 2014, 13:07
by Cox
Sej kul da mož vozi sem stvari pa vse to seveda stane svoj denar samo da pa hoces 12.000€ zasluzit na avtu za 4.500 to pa je malo oderuško ...
Re: Iz Amerike
Posted: 19 Feb 2014, 16:50
Prav gotovo noben tega ne dela zastonj,ne vem pa po kakem ključu si naračunal 12k zaslužka. Sicer pa je danes vsem svet na dlani in čisto vsak lahko opravi nakup sam ..
Sem pa imel tudi sam precej podobno razmišljanje,zato sem se spustil v avanturo nakupa avta od tam čez ..verjemi da je bila pri meni nakupna cena avta komaj tretjina končnih stroškov ..z tem da sem avto kupil v New Jerseju ..torej "blizu" porta ..da o drugih dogodivščinah niti ne pišem
Re: Iz Amerike
Posted: 19 Feb 2014, 20:52
by dzanzi
Re: Iz Amerike
Posted: 19 Feb 2014, 21:43
by Cox
Sem napisal da razumem, da ne dela tega zastonj, logično. Ampak 12k€? .. mi je jasno kolk taka usluga stane, ne gledam oglasov na sambi zgolj iz dolgcasa :D ... vseeno se mi zdi oderuško, saj ne rečem .. mogoče se motim in bom potem ko spravim svoj prvi avto preko govoril drugače ... ampak po pogovoru z človekom ki vlači te avte preko že kakih 20 let močno dovmim.
Re: Iz Amerike
Posted: 21 Feb 2014, 00:03
1951 Buick Special Straight V8 - 13.990€
Re: Iz Amerike
Posted: 26 Mar 2014, 02:20
1977 Porsche 911 Targa - 18.300€
a classic 1977 Porsche 911 Targa, Guards red, 2.7 liter. Only one previous owner. Car was purchased in 1986 locally with 20k at the time, has been garaged kept it's entire life. It has 55k original miles. Accident free. If your looking for that old forgotten Porsche that's been sitting in a garage, this is it... It's all stock, all matching numbers. Engine is strong, but needs major maintenance overhaul... New seals, plugs, tune, brake work, All engine components are original.
Re: Iz Amerike
Posted: 01 May 2014, 12:57
3 komadi iz oglasov na evropskih tleh ..
Re: Iz Amerike
Posted: 03 Sep 2014, 00:45
1936 AUBURN SPEEDSTER -37.400€ Rijeka + dajatve
Great Auburn Speedster boat-tail automobile, in very clean condition :o
Re: Iz Amerike
Posted: 03 Sep 2014, 00:48
1959 Harley Panhead - 19.900 Rijeka + dajatve
1959 panhead, new upper end, wish bone frame, nice bike, clear title
Re: Iz Amerike
Posted: 03 Sep 2014, 00:56
1937 Ford Street Rod - 66.900€ Rijeka + dajatve
FOR SALE OR TRADE Finished in 2012 Pro Built by Jim Baker of Texas build was over $195000
with only 1900 miles Everything on this build was Brand New and is NOT from a Donor Car
Downs Body underside of body is finished in Champagne
Downs Chassis sprayed with POR15
Leather Interior by Joe Kennedy of Texas
Paint is Champagne Mist and Prowler Orange on Top
The engine is a new 1996 LT1 350 with aluminum heads professionally built by Street Performance Mena, Arkansas
Street performance serpentine belt set up with chrome brackets and air cleaner
Brand new 4L60E transmission with new converter and Lokar floor shifter
Narrowed 9 inch Ford with 350 Ratio
140 Amp power master alternator
Polished sanden a/c compressor
New Optispark, Water pump and fuel injectors
Red powder coated oil pan and intake
Ceramic coated headers
Borla stainless mufflers
Howell computer wiring harness
PRC aluminum radiator
Aluminum drive shaft
Custom Steel Chrome Plated Grill
Vintique Halogen Headlights with blinkers built in
LED Molded flush mounted tail lights
Jaguar XJ8 Third Brake Light
Billet specialities aluminum tilt steering column
Billet Specialties 14" Steering Wheel Painted to match wrap around custom dash
Front opening hood
Power door poppers with remote
Power window drivers side with remote
Power trunk with remote control
Vintage Air/Heat with defrost,floor,bi-level and vent and controller
Phipps pedals, AC Vents and Door handles,
Auto-meter gauges
Hagan gas filler molded in to the fender
One piece windshield with dual wipers
Sony am/fm cd with remote and 4 speakers
Tubular control arms rack and pinion steering
4 Bar Rear Suspension
Air ride front and rear with compressor and tank in trunk hidden and 2 buttons to raise and lower
Budnik GT flat lip wheels with Yokohama tires 205/50/17 and 235/55/17 on the rear
Wilwood brakes front and rear
Stainless brake lines with power brakes.
Stainless fuel tank and fuel lines
One of a kind build with no corners cut anywhere and the 2 tone paint colors go great together a lot of complements everywhere i take her
There is not a single space on this car that is not outstanding with high attention to detail and craftsmanship. Every single metal part is either billet or polished aluminum or chromed or painted to match
