RaznoRazne
Re: RaznoRazne
Post by Anzee » 31 May 2018, 17:03
To je original odbijac iz Mant A letnik 74 in 75 ki so bile prodane v ZDA. Zaradi regulative je pac mogu met absorbcijske elemente notr in je biu tak ogromn... grdo za popizdit ja..
Re: RaznoRazne
Post by pero27 » 31 May 2018, 17:16
Hecno da so sploh mante v ameriko prodajal :)
Pa ople GT tud, baje so ful redki tam, pa vsi se jim smejijo k zraven korvete parkirajo :lol:
Re: RaznoRazne
Post by DS71 » 07 Sep 2018, 10:13
Re: RaznoRazne
Post by L4UK0 » 12 Sep 2018, 21:17
https://www.facebook.com/Goodwood.Revival
Tudi če ne maraš FB se ga zaradi tega splača imet! 8-)
Re: RaznoRazne
Post by L4UK0 » 21 Nov 2018, 20:09
Med brskanjem o oljnem tlaku sem našel en zanimiv video:
This engine has been running at idle (and an occasional rev to attract people) for hours at a time over the last two years, and has no gauge or sender, second hand oil, second hand filter, and undersize bearing shells with shims to take up the slack. Oil pump of unknown quality, and water in the oil.
It rattles momentarily until the oil flow gets going, then it is fine. The vid was taken a couple of years back, and since then it has been given a radiator, as well as some more cutting from the block, and other minor places.
Controlling the oil flow was the main problem. I don,t have a clue what any pressure might be, if any.
:think: :lol:
malinuc
Avtomobil: mb 190e 2.6
Re: RaznoRazne
Post by malinuc » 16 Dec 2018, 14:07
Ne vem točno kam naj dam tolo povezavo. Če koga zanima majice, delovne majice, predpasniki.... z dobrimi motivi, primer:
https://shop.spreadshirt.com/artsmoto/m ... 87&page=10
Re: RaznoRazne
Post by pero27 » 11 Jan 2019, 15:49
OLDSCHOOL-Nig.com chapter :)
kadett69
Re: RaznoRazne
Post by kadett69 » 29 Mar 2019, 09:30
Zasledil sem en članek, ki je vsaj meni čisto skregan s stroko:
https://www.avto-magazin.si/novice/na-b ... MH7uXwhjCU
V Centru mobilnosti Špan so predstavili napravo, s katero po novem lahko poskrbijo za obnovo vseh vrst aluminijastih platišč, tudi modernih dvobarvnih.
Re: RaznoRazne
Post by Fleko » 29 Mar 2019, 11:51
Sem samo preletel članek, kaj naj bi bilo skregano s stroko?
Diamont cut se temu postopku ponavadi reče.
JureK
Avtomobil: VW T3
Re: RaznoRazne
Post by JureK » 29 Mar 2019, 11:54
Sem videl ta stroj v živo pri Španu. Nič posebnega, CNC stružnica pač, namesto stružnega noža dajo notri biax in to je to. Verjetno (predvidevam), da ima vgrajen tudi skener, ker po moje ne modelirajo vsake felge posebej. Ko sem bil tam sicer ni obratovala tako, da hitrosti dela ne morem komentirat, lahko pa rečem, da mi ne deluje ravno rocket science. Podatki o vzdržljivosti rezkarja pa so malo čudni ja...
