Zastava 850
Re: Zastava 850
Olje sem vzel v firmi kjer delam
Za več info sn ti pa poslal PM.
Re: Zastava 850
sej mogoče bi še koga zanimalo
dej kšno specifikacijo,pa ceno ..tukaj je,mimgrede,forum starodobnikov
Re: Zastava 850
neki gledam ..mineralna olja, imajo pa samo API specificiran .. tako da bo treba njim verjet ..
https://www.oest.de/media/pdf/de/07-oes ... cht_de.pdf
SG-Obsolete For model year 1993 and older engines.
SF-Obsolete For model year 1988 and older engines.
SA-Obsolete For older engines; no performance requirement. Use only when specifically recommended by the manufacturer.
CC-Obsolete Service typical of certain naturally aspirated, turbocharged or supercharged diesel engines operated in moderate to severe-duty service, and certain heavy-duty gasoline engines. Oils designed for this service provide protection from bearing corrosion, rust, corrosion and from high to low temperature deposits in gasoline engines. They were introduced in 1961.
CD-Obsolete Service typical of certain naturally aspirated, turbocharged or supercharged diesel engines where highly effective control of wear and deposits is vital, or when using fuels with a wide quality range (including high-sulfur fuels). Oils designed for this service were introduced in 1955 and provide protection from high temperature deposits and bearing corrosion in these diesel engines.
CF-Obsolete Service typical of indirect-injection diesel engines and other diesel engines that use a broad range of fuel types, including those using fuel with high sulfur content; for example, over 0.5% wt. Effective control of piston deposits, wear and copper-containing bearing corrosion is essential for these engines, which may be naturally aspirated, turbocharged or supercharged. Oils designated for this service have been in existence since 1994 and may be used when API Service Category CD is recommended.
Re: Zastava 850
Pozdravljeni, še dihamo
ne morem verjeti da je skoraj leto naokoli.
Pa da na kratko povzamem fičko je še vedno v enem kosu
Na začetku sem odpravil par majhnih težavic z bremzami, ter pregrevanjem, nato pa sem se samo vozil, kolikor mi je pač čas dopuščal, po večini bolj kratke turce, ampak se je vseeno nabralo dobrih 800km
Se je pa avto vmes malo popucal, predvsem od znotraj, ter dobil original črno usnjene zice
Before
After:
Pa še malo kar tak.
Pa leti tut
Ker pa eden ni nobeden...
Pa je že gužva
No to pa je bilo to za leto 2016.
Lp
klemen
Before
After:
Pa še malo kar tak.
Pa leti tut
Pa je že gužva
Lp
klemen
Re: Zastava 850
Niso švoh tele zici!
Jst šparam ene enake vinilne, samo rdeče, ki jih je fotr pobral iz svojega prvega avta že kakih 30 let nazaj
Bo treba počas enga belga al pa baby blue fičota najt za not jih zmontirat!
- grega983
Re: Zastava 850
Jebene svinje od ličarjev. Avto ni kaj prida vreden, barva pa še po armaturki....
Re: Zastava 850
Zici zgledajo super, edino poleti bo pečica
Sedeže si kupil take al si dal kaj tapicirat? Iščem nekega pametnega tapetnika za vredu dnar za e21..
Mimogrede - kakšni so občutki s fičkotom pri taki hitrosti? Enkrat sem se z enim iz žlahte peljal malo po mestu, v rondoju pri 40km/h mi je že švic tekel..
Re: Zastava 850
Sedeži so original, nič preoblačeni. Zato sem jih tudi vzel,ker je bla prilika in so res ohranjeni v nulo, je pa poleti res malo vroče
. Glede preoblačenja v mb ti pa žal ne znam svetovat.
Glede pobarvane armaturke, tepihov, itd. nekaj so popravljali pa so zgleda kr doma tak malo pihnili, ampak bo vse poštimano.
Lp
Klemen
Lp
Klemen
